ERROR 999999 appears while trying to run a python script using arcpy functionalities through Task Schedular
3718
8
08-01-2024 07:48 AM
Murtaza_Mir
I have written a python script that is using arcpy as well. One of the functions that I am using is the arcpy.management.CreateTable. I created a batch file that calls this script. When I run the batch file directly, the script runs fine with no errors but when I use a Task Schedular instead to call the batch file for running the script, I run into the following error:
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to execute (CreateTable).
The error appears while trying to create the Table. I don't understand what is the cause of this. Any suggestions?
Thank you
Tags (3)
Murtaza_Mir
I figured out the actual cause. The licensing issue was happening because I was storing the created table in ScratchGDB. Apparently, this was causing the issue to fail. When I changed the location for the table, the error got fixed. Thank you @MichaelVolz  and @MErikReedAugusta  for pointing me in the right direction.
MErikReedAugusta
MVP Regular Contributor
Maybe it could be a licensing issue?  Try setting the scheduled task for a time during the day when you're there and make sure you're logged into both the machine running the script and into ArcPro, then see if it still fails.
I haven't run any task-scheduled scripts yet, myself, but I remember a discussion a while back on one of the GIS communities I follow where someone had a similar problem.  The script was trying to run in the middle of the night, and the machine that was trying to run it wasn't logged into ArcPro at that time of night.  Don't remember if they got a 999999 from it or not, though.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
MichaelVolz
Esteemed Contributor
Does your script fail every time or is it more of a random failure in Task Scheduler?
Check your Event Viewer as that helped me find issues with python scripts.
Murtaza_Mir
The script fails every time with the Task Scheduler. The script otherwise runs fine when I run the batch file directly. It does not appear to be any issue with any code.
MichaelVolz
Are you running Task Scheduler with highest privilege?
Murtaza_Mir
Yes, the script is running with the highest privilege. Is there a possibility that somehow when the script is run through the scheduler, it does not retain the licenses? I am using a cloned version of base python environment of arcgis pro with a few additional packages, not the base environment itself.
MichaelVolz
Can you try creating a simple script just importing arcpy with a print statement before and after the import statement in the standard python environment, that is called from a bat file?
This is what I needed to do at my org to determine that anti-virus software was interfering with running a python script thru Task Scheduler even though it ran fine when just running directly from the bat file.
Murtaza_Mir
Murtaza_Mir
It may be a licensing issue although I wonder how does the batch file directly runs successfully. I will try that as well. Thank you for the suggestion.
