ERROR 000372: Spatial Reference for output is invalid
4014
01-19-2011 08:55 PM
tongkimongki
Hi all,
Iam trying to copy/load featureclass/data from one geodatabase to another (using LOAD or export), then
I get an error
Start Time: Thu Jan 20 13:15:57 2011
ERROR 000224: Cannot insert features
ERROR 000372: Spatial Reference for output is invalid, Please update to allow output to become valid
Failed to execute (FeatureClassToFeatureClass).
Then i remove all objects that listed in the error message that causing the error. Then copy/load again. Same error comes up.
Then from the help, it says "The tool failed while trying to set the spatial grid index(es) for the output." I have done recalculate the grid index by recalculate the spatial index (right click the feature class --> Properties --> Tab Indexes --> Recalculate). Then I try to load it again but the same error message comes up again.
How do you fix this ? I was able to Load them before but this time it just failed. I am wondering why i was able to load the data into the new geodb before... 😞
I am using Oracle 10G with SDE 9.3.0
thanks
AndrewCox
Tongki,
I am having the same problem, did you ever find a solution to this problem?
Andy
