Enterprise Geodatabase Security
3243
03-23-2013 04:48 AM
EmadAl-Mousa
My Question: what are the Enterprise Geodatabase Security Implementations ?
in any big organizations that are implementing GIS Infrastructure based on ESRI products, security is an important aspect. As an SDE Geodatabase Administrator what security best practices should i implement ?
FYI: reference article i have read: http://wiki.gis.com/wiki/index.php/Information_Security
VinceAngelo
Esri Esteemed Contributor
You should always implement all best practices.  Picking and choosing on security
practices often has the same result as not implementing any.
- V
EmadAl-Mousa
to clarify my question more, per ESRI guideline what are security strategies for Enterprise Geodatabase ?
is there any clear documentation regarding geodatabase security ? becauase i could not find any ....
MarcoBoeringa
One basic thing to remember is that a geodatabase resides in an RDBMS. It means any valid RDBMS security policies also holds for your geodatabase. That said, there are other tips and things documented in ESRI papers.
Some links:
Authentication in ArcGIS
http://video.arcgis.com/watch/2197/authentication-in-arcgis
Building an Enterprise GIS �?? Best Practices, Design Strategies and Performance Benchmarks
http://blogs.esri.com/esri/arcgis/2011/08/26/building-an-enterprise-gis-best-practices-design-strate...
Designing an Enterprise GIS Security Strategy
http://downloads2.esri.com/resources/enterprisegis/feduc2011security.pdf
http://resources.arcgis.com/en/communities/enterprise-gis/01n200000004000000.htm
ArcGIS 10.1 Enterprise Deployment
http://support.esri.com/en/knowledgebase/whitepapers/view/productid/66/metaid/1896
http://downloads.esri.com/support/whitepapers/other_/1896J9736_ArcGIS_Enterprise_Deployment.pdf
Marco
EmadAl-Mousa
Thanks Marco
