domain
4676
14
09-07-2016 03:11 AM
jayasudha
I have created a feature class in WGS84 with default settings.
There is default domain created as below. What does it mean ?
xmin, xmax (-400, 9006799.25474099)
ymin, ymax (-400, 9006799.25474099)
NeilAyres
See here :
Feature domains
jayasudha
I have already seen this. It is about resolution, tolerance. But not domain. Please advice..
DanPatterson_Retired
have you tried the obvious of creating a new geodatabase using default settings, then creating a new featureclass?  You will have something to compare to at least.  And if possible, get someone else to log in to your machine and do the same to ensure it isn't a profile issue as well
jayasudha
Thanks to all for discussion.
It is not issue, but trying to understand...
JoeBorgione
Oops... My bad...
