Direct Connect DLLs
10385
33
10-22-2009 03:27 PM
TedCronin
Original Post Date: Oct 22, 2009 4:27 PM PDT
On the old install for Desktop these were a part of the install, but then I heard they were on the same "disk" for SDE, is that the case, or are they just incuded as part of the install for desktop.  Trying to connect from 94 to 931.
MichaelOlkin
I just installed ArcGIS Desktop 9.4 beta & the first issue that I've found is that I'm unable to create a new connection from ArcCatalog 9.4 to our existing 9.2 ArcSDE Enterprise Geodatabase.  I've tested out a couple *.sde connection files to that same database that we have on our network & these work on 9.4, but I just can't seem to create a new connection in 9.4.  I've tested a couple different logins & I've verified that I have all of the parameters & credentials correct.
-Mike O
TedCronin
RobertWest
Did you see the answers posted in the ArcGIS Server Installation/Config forum?
Robert
TedCronin
Yep, it was me who posted it there, originally.  Very helpful.  Oops, your not referring to me, are you?
This should be helpful.
Ted,
this message means that your SQL Server Native Client is not up to date. At 9.4, when connecting to SQL Server, you must have the SQL Server Native Client installed locally that matches, or is newer, than the SQL Server instance you are trying to connect to. If you are connecting to SQL Server 2008 you need to have the 2008 Native Client. It is downloadable from here:
http://www.microsoft.com/downloads/details.aspx?FamilyId=C6C3E9EF-BA29-4A43-8D69-A2BED18FE73C&displa...
-Shannon
BuddyNagel
I get a error message when connecting to ArcSDE 9.2 SP5 or 9.3 SQL Server 2000. Failed to connect to database. Connection was attempted with an older version.........
Buddy
MichaelOlkin
Thanks for the response on this.  I actually wasn't using direct connect & it turns out that the issue was my own error.  My existing 9.2 enterprise geodatabase is on a SQL Server 2000 named instance; I was using this convention: <server>\<instance> when attempting to connect, when all that I needed was just the server name.
All set now!
RobertWest
Please check this thread
http://forumsbeta.esri.com/showthread.php?t=91
and see if Shannon's answer is what you need.
Robert
EugeneYang
Regarding the original question.
If you installed ArcGIS 9.4 beta, you don't need to install any direct connect drivers separately. All the necessary pieces to make backward direct connect to 9.3, 9.3.1, 9.2SP6 are already included.
Eugene
TedCronin
except the native client, mentioned above.
SteveAdams
I had the same problem so I installed the Microsoft SQL Server Native Client for sql server 2005.  I can now do Test connection and it works, but when I click ok I get another error.
DBMS table not found[Microsoft SQL Native Client: invalid object name 'databasename.dbo.GDB_Items'.][databasename.dbo.gdb_Items]
