Diagrammer - unable to change spatial reference
846
10-05-2011 08:04 AM
by Anonymous User
Not applicable
Is it 'user error' on my behalf or is there a bug whereby a fc created with diagrammer does not respect changes to the spatial reference & retains the GCS_WGS_1984 definition?  While the diagram appears to save the changes, as does the published xml, its loosing the spatial ref config upon import into the gdb.
Appreciate if anyone can clarify this issue for us.
Brad
GIS-Cambria
Brad,
It's been a while since I've altered projections in Diagrammer. In fact I'm looking into using it again for just that reason. Spatial References in the properties seem to be tricky. If you're setting a Feature Dataset make sure to set the Spatial Reference under Extent and Spatial Reference. It's the same process for a feature class, but you can enable M and Z values there. It takes time to get all of that set, especially on a large GDB. It would be great to set a default projection set or run a tool to change all to match..... I think I posted that on ideas once....
