Dgn files in 10.2 version
9717
14
08-06-2013 11:06 PM
jordixirgo
MicroStation V8/V7 DGN files displays incorrectly in ArcMap/Catalog 10.2.0.3348, without coordinates.
The same file in 10.1 or 9.3.1 displays correctly
DavidMcMillan1
It seems to work, but that seems like a terrible fix.  Has their been a solution yet?
Dave
JayCarpenter
Same issue here.  I had a dgn referenced into arcmap that I occasionally opened to make small exhibits, now after installing 10.2.1 from 10.1 the dgn shows up in the wrong location.
JacquelineTucker
We are experiencing the same issue here. We using ArcGIS 10.2 . Most of dgn's that are causing problems are ones that are imported from other users/department.
We need a fix to this ASAP! ESRI keeps saying this is caused by a corrupted world file. Is the issue still present in 10.2.1?
JayCarpenter
I found a possible fix referenced in the following document regarding issues to be fixed in 10.2.2 due out soon I think.
http://support.esri.com/en/downloads/patches-servicepacks/view/productid/67/metaid/2069
deleted-user-ZUbHWeAIF9xZ
Hi Everyone,
ESRI issued a QFE that fixes NIM094291 on ArcGIS 10.2.1. You don't have to wait or upgrade to 10.2.2 to get this fix. I was able to apply that patch that solved this issue.
Subbu
