Default drawing order when loading a raster catalog in ArcMap
1830
09-09-2013 09:45 AM
CarolaEklund1
Hello -
My issue may sound trivial, but when adding a raster catalog (stored in a file gdb) to an mxd, it seems to load on top of the polygon layers that are already there rather than below them (as would be expected for image/raster data).
- Almost as if ArcMap interprets it as a �??polygon�?? layer.
I know, I can easily drag the layer down in the table of contents. Thing is, we have users that load raster catalogs via a button on a customized drop down menu - to make it as easy as possibe for them. Usually they are not that GIS/ArcMap savvy and oftentimes get startled by the described behavior and don�??t know how or don�??t remember that the drawing order can easily be changed.
My question: shouldn�??t any type of image data automatically/by default load underneath any polygon layer in the table of contents? And more importantly: is there a way to change this behavior? Maybe some settings someplace? (I�??m working in ArcGIS 10.0 SP5)
Thanks for any tips/insights!
JakeSkinner
Esri Esteemed Contributor
Hi Carola,
I would recommend using a Mosaic Dataset rather than a raster catalog.  Mosaic Datasets perform much faster than raster catalogs, and you have additional benefits such as on-the-fly processing.  Also, when adding a mosaic dataset to an ArcMap session, it is added to the bottom of the table of contents.
CarolaEklund1
Thanks for getting back with me, Jake. This image data is being shared with several agencies in our region. I did not create the raster catalog nor the gdb it's stored in and don't have rights/permissions to make any changes either - so I'm 'stuck' with what I got. ... just thought there might be a way to 'tweak' the default drawing order and I had just been missing something here. ..I will check what the reasoning behind creating a raster catalog rather than a mosaic dataset was and if it could be considered changing the format.
