Data Interop Install
1549
10-22-2009 03:09 PM
TedCronin
Original Post Date: Oct 22, 2009 4:09 PM PDT
Where is Interop as an extension?  This is still part of the install, correct?
BruceHarold
Esri Frequent Contributor
Hi Ted
Data Interop didn't make it into Beta 1, it will be in Beta 2.
Regards
Bruce H.
ESRI Redlands
TedCronin
Whats new for Data Interop for 94?
AllisonRost
Hi Ted,
DIE at 9.4 is supposed to be the equivalent release of FME 2010. New functionality you should see is:
5 new formats added
Updates to many formats
29 transformers added
Support for pasting workbenches into Spatial ETL tools
Workspace search
You should see DIE as an extension at Beta 2.
Allison...
ESRI Support Techincal Lead
KristinBailey
How can I turn off this error message:
"Warning: The Data Interoperability (Interop) license has expired.
I Receive a warning when first opening up ArcMap/ArcCatalog.  I've had this happen with 9.3.1 and fixed it by turning off the message in AdvancedArcMapSettings.exe.  ArcGIS 9.4 did not install this .exe, therefore I have no way of turning off this message.
Kristin
RuiSantos_EsriPT
Hello,
Have you tried to remove the corresponding lic file?
Check on:
C:\Program Files\ESRI\License9.4\AESingleUser\InteropFX.lic
Regards,
Rui Santos
Com os nossos melhores cumprimentos,
Rui Santos | Senior Account Manager | Educação, Cultura e Startups
Esri Portugal | Rua das Vigias,2, 1ºA | 1990-506 Lisboa | Portugal
T +351 217 816 640 | M +351 918 126 333 | [email protected] | esriportugal.pt
THE SCIENCE OF WHERE™
