data from AutoCAD Map 3D 2011 to ArcGIS (ArcMap) 10.
543
06-30-2011 11:06 PM
ChristianLehmann
i want to import DGW-data (or in general AutoCAD-data) from AutoCAD Map 3d 2011 into ArcGIS 10.As I suppose, ArcGIS could recognize only DWG or shp.
The most important information for me are the styles (color, linetype ....). The feature class Line is not the main problem, but when i want to export points or polygons it is difficult. AutoCAD seperate points or polygons in fill colors und edge colors and only the edge color are able to import in ArcGIS. Another fact is that ArcGIS seperate a Point into featureclass Line (the edge) und Polygon and the spatial information failes (that works with ArcToolbox feature "CAD to Geodatabase", all not my problem).
To summarize there are any problems with the transformation of styes.
Wenn I export SDF-layer as Shapefile its a good way to transform spatial information (coordinate system) und the data of attributtables, but my problem are the colors und styles.
Do anyone know, how i can transport all (point, line, polygon) styles from AutoCAD Map 3D 2011 to ArcGIS 10?
About an answer I would be very happy
Best regards
Chris
