DAT data
2479
03-29-2013 03:25 AM
AnLat
I am trying to introduce the 5 degree dataset from here http://www.cru.uea.ac.uk/cru/data/precip/ (it is the first link). And once I introduce it to GIS to use it as a raster input to calculate zonal statistics using as feature zone the world borders (http://thematicmapping.org/downloads/world_borders.php).
My first question is how to introduce the dat data into GIS.
An second, once I introduce it can I use it as a regular raster file and do zonal statistics?
Can anyone help? I use ARCGIS 10.1
Thanks!
JeffreySwain
ArcMap does support .DAT files in a certain format.  After reading the documentation on your data, I am not sure if that is the format that is supported. With questions like this, I always look into this document
Envi .dat , AIRSAR .dat files, and USGS .dat files are supported per the document. I am not sure if the UK information follows those specifications.
Once it is added as a raster in ArcMap, you can pursue either way to  analyze the data.
