Cut polygon with polygon
990
09-14-2011 05:56 PM
LouiseDuffy1
I have been looking and looking for a way to cut a polygon shapefile by another polygon shapefile.  I do not want to use the trace tool.  That would take too long.  Please, someone tell me what tool I am missing!
TerrySilveus
Have you looked at the clip tool?  Would that serve for your purposes?
KenBuja
MVP Esteemed Contributor
How about using the "Replace Sketch" context menu tool? See the tip halfway down the page on this Help topic
QuinnMcCarthy
You can select the poly you want to use at the clip feature and then hit the split polygon button.
Hope that helps.
Quinn
audreygraham
you can also try the erase tool.
