Cut polygon tool not working properly
801
08-07-2013 05:40 AM
JosephHaas
ArcMap - ArcView 10
Have a fairly basic parcel map, need to cut some parcels into two or more separate parcels.  However, on some of them it doesn't actually divide the polygons.  The line shows up, but the two (or more) sections are not selectable, its still just 1 large polygon.  So this presents two basic problems:
1. I need to reverse what was done before.  Unfortunately those edits are already saved.  I can't figure out how to remove those lines that were drawn previously.
2. I need to find a way to cut these polygons properly so that I have two separate parcels, each individually selectable and editable in the attribute table.
Any help would be greatly appreciated.  Thank you.
