Customizng the create features window question
1475
04-30-2012 09:09 AM
MathewAyite_Cambell
At my new job, editing and adding features quickly is very important.
We're working with a lot of different features, however some of them we use sparsely, while other we are using all them time. We've already grouped the layers into different categories, but I was wondering if there was a way to change which features or group of features are located near the top and near the bottom. The creature features window doesn't work like the table of contents window, where you cans simply drag layers up and down as you please. So is there a way I can place certain features near the top and certain features near the bottom? It is very important so please let me know.
- Thank you in advance.
RhondaGlennon
There are a few options for how to group feature templates. In your case, you might try grouping by frequency, so the templates you use most often appear near the top of the window. Otherwise, there is not a way to list templates to match the drawing order in the table of contents.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Grouping_feature_templates_in_the_Crea...
