Creating points from excel/access
1504
6
12-17-2012 08:10 AM
NicoleHanson
I'm trying to create points from the excel/access table.  I have Lat/Long, and they are in a format like: 462508 for Lat and 1163445 for Long.  It's not creating a shapefile that I would expect.  Is there any way to calculate these values into Decimal Degrees?
michaelcollins1
Looks like your coordinates are UTM based (or something similar). Create your shapefile using the proper UTM zone, then pop it onto your map, then create 2 new fields for LAT and LON and populate them using Calculate Geometry
NicoleHanson
What would the calculation be for the new fields?
michaelcollins1
NicoleHanson
OK, I did that, but it seems to be shifted from other data I have in ArcMap.
michaelcollins1
Shifted by how much? Perhaps you used NAD83 instead of NAD27 or vice versa.
NicoleHanson
It was more of a spreading and shifting.
I asked a coworker for some help, he knows python, and he was able to get the data changed to DD.  Thanks for your help.
