Creating a polygon from a reclassified raster
918
11-05-2013 08:54 AM
by Anonymous User
Not applicable
Original User: eddie416
I'm having some issues coming up with a plan on how to solve my problem. Basically, I want to reclassify a raster with values 0-255 (see capture1). I want all areas with imagery to be reclassified to a value of 1 and all black areas to be reclassified to a value of 0. The issue is, the black areas don't contain all 0 values.
This is an issue because the end goal is to create a polygon that only encompasses the area that contains imagery. When I reclassify, it looks like capture2 (see attached). I can't pick a range of values to select the black area because then I will be selecting pixels in the imagery as well.
Can anyone come up with a solution to this? Could I use some sort of line detection process to do this or is there another way?
Appreciate any help!
