Create perpendicular lines regular intervals
2903
08-09-2013 11:10 AM
SeanWray
I have created a line which consists of many segments. I'd like to find a way to create a perpendicular line at the END of the existing segment.
Another approach might be to merge all the segments and then create verticies and then create perpendicular lines at the verticies.
I'd like to do this using editing tool or a tool in the tool box. I never seem to understand how to use most of the code i find here.
ChristopherBlinn1
This post provides a tool you can download that may be just what you're looking for.
I have not tested this tool but from your description, this tool should be able to get you closer to your goal.
Hope it helps!
Chris B.
