Create Enterprise Geodatabase with arcpy - Invalid license file provided!
6220
09-10-2012 04:59 AM
VasiliiSelivanov
Hi. I'm trying to create geodatabase in ArcGIS for Server enterprise with arcpy script. But it's falling with exception Invalid license file provided. Please provide an ArcGIS for Server enterprise keycodes file!
But i've got licenced ArcGis for Server enterprise!!! I can't understand why this script is not working!?
Description: Provide connection information to a DBMS instance and create an enterprise geodatabase.
Type  create_enterprise_gdb.py -h or create_enterprise_gdb.py --help for usage
Author: Esri
# Import system modules
import arcpy, os, optparse, sys
# Define usage and version
parser = optparse.OptionParser(usage = "usage: %prog [Options]", version="%prog 1.0 for 10.1 release")
#Define help and options
parser.add_option ("--DBMS", dest="Database_type", type="choice", choices=['SQLSERVER', 'ORACLE', 'POSTGRESQL', ''], default="", help="Type of enterprise DBMS:  SQLSERVER, ORACLE, or POSTGRESQL.")
parser.add_option ("-i", dest="Instance", type="string", default="", help="DBMS instance name")
parser.add_option ("-D", dest="Database", type="string", default="none", help="Database name:  Not required for Oracle")
parser.add_option ("--auth", dest="Account_authentication", type ="choice", choices=['DATABASE_AUTH', 'OPERATING_SYSTEM_AUTH'], default='DATABASE_AUTH', help="Authentication type options (case-sensitive):  DATABASE_AUTH, OPERATING_SYSTEM_AUTH.  Default=DATABASE_AUTH")
parser.add_option ("-U", dest="Dbms_admin", type="string", default="", help="DBMS administrator user")
parser.add_option ("-P", dest="Dbms_admin_pwd", type="string", default="", help="DBMS administrator password")
parser.add_option ("--schema", dest="Schema_type", type="choice", choices=['SDE_SCHEMA', 'DBO_SCHEMA'], default="SDE_SCHEMA", help="Schema Type for SQL Server geodatabase, SDE or DBO. Default=SDE_SCHEMA")
parser.add_option ("-u", dest="Gdb_admin", type="string", default="", help="Geodatabase administrator user name")
parser.add_option ("-p", dest="Gdb_admin_pwd", type="string", default="", help="Geodatabase administrator password")
parser.add_option ("-t", dest="Tablespace", type="string", default="", help="Tablespace name")
parser.add_option ("-l", dest="Authorization_file", type="string", default="", help="Full path and name of authorization file")
# Check if value entered for option
try:
 (options, args) = parser.parse_args()
 #Check if no system arguments (options) entered
 if len(sys.argv) == 1:
  print "%s: error: %s\n" % (sys.argv[0], "No command options given")
  parser.print_help()
  sys.exit(3)
 #Usage parameters for spatial database connection
 database_type = options.Database_type.upper()
 instance = options.Instance
 database = options.Database.lower()
 account_authentication = options.Account_authentication.upper()
 dbms_admin = options.Dbms_admin
 dbms_admin_pwd = options.Dbms_admin_pwd
 schema_type = options.Schema_type.upper()
 gdb_admin = options.Gdb_admin
 gdb_admin_pwd = options.Gdb_admin_pwd
 tablespace = options.Tablespace
 license = options.Authorization_file
 if (database_type == "SQLSERVER"):
  database_type = "SQL_SERVER"
 if( database_type ==""):
  print " \n%s: error: \n%s\n" % (sys.argv[0], "DBMS type (--DBMS) must be specified.")
  parser.print_help()
  sys.exit(3)
 if (license == ""):
  print " \n%s: error: \n%s\n" % (sys.argv[0], "Authorization file (-l) must be specified.")
  parser.print_help()
  sys.exit(3)
 if(database_type == "SQL_SERVER"):
  if(schema_type == "SDE_SCHEMA" and gdb_admin.lower() != "sde"):
   print "\n%s: error: %s\n" % (sys.argv[0], "To create SDE schema on SQL Server, geodatabase administrator must be SDE.")
   sys.exit(3)
  if (schema_type == "DBO_SCHEMA" and gdb_admin != ""):
   print "\nWarning: %s\n" % ("Ignoring geodatabase administrator specified when creating DBO schema...")
  if( account_authentication == "DATABASE_AUTH" and dbms_admin == ""):
   print "\n%s: error: %s\n" % (sys.argv[0], "DBMS administrator must be specified with database authentication")
   sys.exit(3)
  if( account_authentication == "OPERATING_SYSTEM_AUTH" and dbms_admin != ""):
   print "\nWarning: %s\n" % ("Ignoring DBMS administrator specified when using operating system authentication...")
 else:
  if (schema_type == "DBO_SCHEMA"):
   print "\nWarning: %s %s, %s\n" % ("Only SDE schema is supported on", database_type, "switching to SDE schema..." )
  if( gdb_admin.lower() == ""):
   print "\n%s: error: %s\n" % (sys.argv[0], "Geodatabase administrator must be specified.")
   sys.exit(3)
  if( gdb_admin.lower() != "sde"):
   if (database_type == "ORACLE"):
    print "\nGeodatabase admin user is not SDE, creating user schema geodatabase on Oracle...\n"
    sys.exit(3)
   else:
    print "\n%s: error: %s for %s.\n" % (sys.argv[0], "Geodatabase administrator must be SDE", database_type)
    sys.exit(3)
  if( dbms_admin == ""):
   print "\n%s: error: %s\n" % (sys.argv[0], "DBMS administrator must be specified!")
   sys.exit(3)
  if (account_authentication == "OPERATING_SYSTEM_AUTH"):
   print "Warning: %s %s, %s\n" % ("Only database authentication is supported on", database_type, "switching to database authentication..." )
 # Get the current product license
 product_license=arcpy.ProductInfo()
 # Checks required license level
 if product_license.upper() == "ARCVIEW" or product_license.upper() == 'ENGINE':
  print "\n" + product_license + " license found!" + " Creating an enterprise geodatabase requires an ArcGIS for Desktop Standard or Advanced, ArcGIS Engine with the Geodatabase Update extension, or ArcGIS for Server license."
  sys.exit("Re-authorize ArcGIS before creating enterprise geodatabase.")
 else:
  print "\n" + product_license + " license available!  Continuing to create..."
  arcpy.AddMessage("+++++++++")
 try:
  print "Creating enterprise geodatabase...\n"
  arcpy.CreateEnterpriseGeodatabase_management(database_platform=database_type,instance_name=instance, database_name=database, account_authentication=account_authentication, database_admin=dbms_admin, database_admin_password=dbms_admin_pwd, sde_schema=schema_type, gdb_admin_name=gdb_admin, gdb_admin_password=gdb_admin_pwd, tablespace_name=tablespace, authorization_file=license)
  for i in range(arcpy.GetMessageCount()):
   arcpy.AddReturnMessage(i)
  arcpy.AddMessage("+++++++++\n")
 except:
#Check if no value entered for option
except SystemExit as e:
 if e.code == 2:
  parser.usage = ""
  print "\n"
  parser.print_help()
  parser.exit(2)
This is output of the execution of above python script:
C:\Python27\ArcGISx6410.1>python createArcgisDatabase.py --DBMS=SQLSERVER -i ARC
GISSQLSERVER -D kostroma -U sa -P 112 -u sde -l C:\Program Files\ESRI\License10.
1\sysgen\keycodes
ArcServer license available!  Continuing to create...
Executing: CreateEnterpriseGeodatabase SQL_Server ARCGISSQLSERVER kostroma DATAB
ASE_AUTH sa ***** SDE_SCHEMA sde # # C:\Program
Start Time: Mon Sep 10 16:36:42 2012
ERROR: Failed to execute. Parameters are not valid.
ERROR: Invalid license file provided. Please provide an ArcGIS for Server enterp
rise keycodes file.
ERROR: Failed to execute (CreateEnterpriseGeodatabase).
Failed at Mon Sep 10 16:36:42 2012 (Elapsed Time: 0,00 seconds)
I will appreciate any help=)
VinceAngelo
Esri Esteemed Contributor
Does the same license file work through the Toolbox utility?
This is really something best taken to Tech Support and/or Customer Service,
since no one here can (or should) verify your license file.
- V
MandarPurohit
Hi Vselivanov,
You will need to provide the path and the filename of the keycodes file for this 'Create Enterprise Geodatabase' to pick up the license.
As described on the webhelp link of the "Create Enterprise Geodatabase" tool:
"Provide the path and file name of the keycodes file that was created when you authorized ArcGIS for Server Enterprise. This file is in the \\Program Files\ESRI\License<release#>\sysgen folder on Windows and /arcgis/server/framework/runtime/.wine/drive_c/Program Files/ESRI/License<release#>/sysgen directory on Linux."
You can also use a .ecp file by downloading it from ArcSDE 10 and ArcIMS 10 Authorization Form.
- Mandar
VasiliiSelivanov
Thanks a lot for fast response. But I found out that problem was in the provided parameters for python script.
Then I passed the path to license key like C:\Program Files\ESRI\License10.1\sysgen\keycodes inside python script in licence variable
was only C:\Program, so that is why it's falling with not appropriate license! All problem was in a gap between Program and Files=)
Nevertheless, thanks=)
