I keep getting an "Error 000042: Failed to create the address locator" message every time I try to create a new locator inside of a file geodatabase. I'm able to create the locator outside of a GDB with no problem. I checked the solution for the error message and tried the applicable suggestions with no success.
system info:
ArcGIS Desktop 10.1
Windows 7 64-bit
000042: Failed to create the address locator.
Description: The address locator cannot be created.
Solution: Check that you have
Permission to write to the disk or database
Enough disk space for the address locator you tried to create
Valid network or database connection
Valid geocoding rule files
Valid address locator style
