Copying feature linked annotation when the spatial references do not match
986
07-01-2010 10:01 AM
ChrisDunlop
Hello.  I'm trying to copy featureclasses (stand alone) from a file geodatabase into a feature dataset in SDE.  The feature dataset projection info is the same as the featureclasses.  I used the default tolerances and resolutions when I created the feature dataset.
I need to copy a point featureclass, and an associated feature-linked annotation featureclass.  If I copy and paste, it gives an error saying the spatial references do not match.  If I Import Featureclass (multiple), it copies the 2 featureclasses, but not the relationship class that links them.
Ideas??  Any help would be appreciated.
Chris Dunlop
City of Oregon City
KevinBingham
Chris-
Did you find a solution to this issue?  I have run into the same problem.
Kevin B.
