CONVERT TO KML
2433
11-16-2013 07:47 PM
JohnsonKollakkaran
Hello,
I want to convert a feature class to kml, which is part of a FGDB, the same feature class contains a field of raster which contain photos. I want to convert this feature class to kml file, which should be displayed the photos too in google earth. Please help me if anyone know the solution.
Regards
Johnson
NidhinKarthikeyan
Honored Contributor
ArcGIS Desktop doesn't have such functionality(to display raster from exported kml in google earth). The kml file will display the point feature and its attributes.
JohnsonKollakkaran
Thanks Nidhin, is there any other software which i can conver to kml with raster image
NidhinKarthikeyan
Honored Contributor
No. As a last resort, you can try SAFE FME. I'm not sure whether it will work.
RobertBorchert
Honored Contributor
What your saying is you have a feature class that is linked to images.
I don't think you can do that.  Instead you may have to create links to the images in Google Earth
Hello,
Regards
Johnson
