Convert points to multipoint feature class
14808
03-06-2011 07:37 AM
RobinZhang
I have a points layer. I'd like to group some of them into point clusters (and leave the rest as is). For all the points that I'd like to make into clusters, I have an attribute field where they share a common value. I thought that I could convert the point feature class to a multipoint feature class based on the common attribute value, but my hypothesis hasn't worked so far. I have tried to create a new multipoint feature class and load the points. I have also tried copy and paste in an editing session. Both cases the same error message: the geometry doesn't match. I would appreciate any suggestions.
JohnSobetzer
Honored Contributor
If you run a dissolve and have a check in the create multiparts features box does that work?
RachelDe_Loza
This was a good tip. I have a similar situation, where I have a point feature class that I want to create a multi-point from.
I performed a Dissolve with the "create multiparts" box checked.
From there I selected the dissolved point feature and using advanced editing tools "Exploded" the points.
From there I selected the desired points and "Merged" them.
The problem here is you won't be able to maintain your original tabular data (though this could possibly be remedied by a spatial join)
Thanks for the tip Sobetzer
KimOllivier
Honored Contributor
Multipoint featureclasses are a separate class from point featureclasses. You can't 'leave the rest alone' in the same featureclass. It doesn't really matter, single points groups will be just the same as a normal point, after a dissolve the featureclass will be multipoint. The problem then is that the featureclass is incompatible with 'singlepoint' so you cannot merge or cut-and-paste, just as you cannot merge lines into polygons [unless you use Workstation].
A further issue you might be trying to solve is to aggregate the multipoints into a single point. This would require a different tool, which finds the centroid of the cluster to place a single point.
