Control resampling method of tile cache
1414
12-23-2016 09:38 AM
JayJohnson
I have a tile cache of orthophotos.  When I add this to ArcMap, the tile cache uses Nearest Neighbor to resample - I want it to use Bilinear.  I have the Customize, ArcMap Options, Raster Layer, Enable Custom Rendering Defaults set to Bilinear, and this DOES control the resampling method applied to individual rasters added to ArcMap, but DOES NOT control the resampling method of the tile cache when it is added.  Is there any way to control the resampling applied to a tile cache without having to manually set it every time it is added to ArcMap?
ArcMap 10.3.1
