combining similar shape files
2539
11
09-11-2013 05:01 AM
MikeHenson
I have a surveyor working on a survey.  Every evening, we convert his survey file to a shape file.  Next day, he goes out and works on the same survey, he comes in and I convert it to a shape file.  Is there a way to combine these multiple files into one shape file, but not have any duplicate data?  If he surveys points 1 thru 50 on the first day, I make a shape file.  Next day, the file still has points 1 thru 50, but adds 51 thru 100. They way I have been doing it, is to just keep replaceing the file with the newest file, but I am to the point where I need to be adding data to the shape files, and if I edit the shape files in arcmap, I can't replace it with what the surveyors do.
As I re-read this, it seems like rambling!  Bottom line is I need to join shape files with no duplicate data.
Thanks for reading.
MKH
TimWitt
I would use the merge tool, since it seems you added a new field to your dataset?
If both features have the exact same fields, you can use the append tool. With this you don't create a new feature set, because it will just add on the new data to the data you are editing.
MikeHenson
thanks Tim...I think I may be seeing the light! It may be a few days before I have to import a new file, but I will report back!  Thanks again
