Clipping Disconnected Map Cache
1041
11-30-2011 11:51 AM
ShaunEpe
I have two offline Map caches that have been built and I need to clip each Cache to several district boundaries.
The caches work great in ArcGIS 10 but I need to clip the caches for distribution so that each district only receives the part of the cache that covers their area.
Is their a way to do this with ArcGIS 10? I believe you can do this using the Export Map Server Cache tool if you are running ArcGIS Server but is there a way to do it without Server?
Cheers,
Shaun Epe
EICU - Land & Property Information
