Classified Renderer with Mosaic Dataset
1431
03-06-2012 12:11 PM
JasonGreenlaw
I am in dire need of the ability to apply a Classified Renderer to a Mosaic Dataset.  Specificially, I need to import Classified Renderer symbology from a layer file.
My data is frequently changing and I need to be able to apply a color map that extends below & above the minimum and maximum values of my sample datasets.  In order to accomplish this, I had to use ArcObjects/ArcGIS Engine to create a ClassifyColorRampRenderer, apply it to a layer and export it to a Layer File, which was hard enough.  But now I can't even import said symbology because Mosaic Datasets don't support it!  Quite frustrating.
I had a few hits when I searched the forums, and one post (http://forums.arcgis.com/threads/45727-Unable-to-use-a-classified-renderer-on-a-DEM-mosaic-dataset?p...) indicated that this functionality would be available at 10.1.
I am currently still evaluating 10.1 beta 2, and this functionality is still not available.
Has this been fixed for the 10.1 release candidate and/or will it be fixed for the final 10.1 release?
A Raster Catalog *would* work for my purposes, since they support Classified Renderers, but for some reason ArcMap won't allow you to import symbology to a Raster Catalog layer from a Layer File!
Any info would be appreciated.
Jason
JasonGreenlaw
My apologies, I was wrong--this functionality is available at 10.1 Beta 2.  The trick is that you must Calculate Statistics on the Mosaic Dataset before a Classified Renderer can be applied.
Does anyone know if ESRI plans to allow users to import symbology to a raster catalog from a layer file?
Jason
