Change SDE database's collation
1959
11-25-2010 06:27 AM
HenWagner
Hi all,
I am trying to change my DB (sde single, 9.3.1) collation, but some dependencies exist:
Msg 5075, Level 16, State 1, Line 1
The object 'spatial_ref_zunits' is dependent on database collation. The database collation cannot be changed if a schema-bound object depends on it. Remove the dependencies on the database collation and then retry the operation.
The object 'spatial_ref_xyunits' is dependent on database collation. The database collation cannot be changed if a schema-bound object depends on it. Remove the dependencies on the database collation and then retry the operation.
Msg 5072, Level 16, State 1, Line 1
ALTER DATABASE failed. The default collation of database 'static' cannot be set to SQL_Latin1_General_CP1_CI_AS.
Has anyone handled this before?
TIA
Hen
AlexMerkulov
We have the same problem
KonstantinLapine
You will need to drop the constraints dependent on your database collation and recreate them after collation is changed:
--drop constraints
USE [database_name]
GO
IF  EXISTS (SELECT * FROM sys.check_constraints WHERE object_id = OBJECT_ID(N'[dbo].[spatial_ref_xyunits]') AND parent_object_id = OBJECT_ID(N'[dbo].[SDE_spatial_references]'))
ALTER TABLE [dbo].[SDE_spatial_references] DROP CONSTRAINT [spatial_ref_xyunits]
GO
IF  EXISTS (SELECT * FROM sys.check_constraints WHERE object_id = OBJECT_ID(N'[dbo].[spatial_ref_zunits]') AND parent_object_id = OBJECT_ID(N'[dbo].[SDE_spatial_references]'))
ALTER TABLE [dbo].[SDE_spatial_references] DROP CONSTRAINT [spatial_ref_zunits]
GO
--change collation
ALTER DATABASE [database_name] collate SQL_Latin1_General_CP1_CI_AS
--recreate constraints
ALTER TABLE [dbo].[SDE_spatial_references]  WITH CHECK ADD  CONSTRAINT [spatial_ref_zunits] CHECK  (([zunits]>=(1)))
GO
ALTER TABLE [dbo].[SDE_spatial_references] CHECK CONSTRAINT [spatial_ref_zunits]
GO
ALTER TABLE [dbo].[SDE_spatial_references]  WITH CHECK ADD  CONSTRAINT [spatial_ref_xyunits] CHECK  (([xyunits]>=(1)))
GO
ALTER TABLE [dbo].[SDE_spatial_references] CHECK CONSTRAINT [spatial_ref_xyunits]
GO
