CASE Tools - Problem with Grid Sizes Error
874
01-18-2013 10:26 AM
MeleKoneya
We are using Visio 2007 to create XML Geodatabase Schemas.    When importing the XML using the CASE Tools Schema Wizard in ArcCatalog 10 SP5,  we get an error message that states: "Problem with Grid Sizes ..." for each feature class in the workspace being imported.
The last time that I used the Schema Wizard to import the same XML digram about six months ago,   I did not see this error.
We now have had to manually set a Grid Value for Grid 1 for each Feature Class when importing which is a tedious work around.
Has anyone enountered this error and found a way to fix it?
Mele
MeleKoneya
I uninstalled Service Pack 4 for CASE Tools and no longer have this issue.    I am now using ArcGIS Desktop 10 Service Pack 5
with ArcGIS Desktop Case Tools Extension 10 Service Pack 3.
Mele
MeleKoneya
Mele
TrinaNair
I had the same error with ArcGIS 10.1 until I installed SP1 for CaseTools.
