Cannot upgrade a user schema geodatabase
5290
10
04-24-2013 04:48 AM
LAFOSSE_CATELAnnick
Hello
We are trying to upgrade from Oracle 10g/ArcSde9.3 to Oracle 11.2.0.3/ArcSde10.1 on a new server
The data are imported in Oracle 11g.
We install ArcSde
In ArcCatalog, we make a direct connection sde:oracle11:server/instance
We launch the check -> result ok
But when we launch the upgrade we have this error in the sde_setup.log
[Wed Apr 24 12:17:23 2013] Cannot upgrade a user schema geodatabase
when the master schema geodatabase is at a previous release.
The master schema geodatabase must be upgraded first.
[Wed Apr 24 12:17:23 2013] ERROR: Geodatabase schema object install not completed (-522).
In th e sdedc_Oracle.log i have this message
[Wed Apr 24 12:16:53 2013] [27461] [TLSDK4337] db_array_fetch_attrs OCI Fetch Error (28595)
[Wed Apr 24 12:16:53 2013] [27461] [TLSDK4337] load_buffer error -51 on GDB_REPLICAS, rowid -1
Thank you for your help
AsrujitSengupta
I think you guys might be encountering the following Bug:
http://support.esri.com/en/bugs/nimbus/TklNMDg0OTg3
[NIM084987 - When upgrading an ArcGIS 10 SP5 geodatabase to ArcGIS 10.1, while connecting with the syntax 'sde:oracle11g:TNSNAME' the upgrade fails with the error 'ERROR: geodatabase schema object install not completed (-522).']
Regards,
