Cannot select feature with Select Feature tool but can select in attribute table
1244
11-02-2012 03:02 PM
valerieadair
At one time I was able to use the select feature tool on my projects but I am unable to do so now, only from the attributes table. I have checked to make sure the layer is selectable and the interactive selection is checked to new selection. What is odd is that I am unable to use the select tool on all of my projects. Any ideas?
Thanks.
JuanLuera
Hola Valerie,
I would suggest the following items to see if they help�??s resolve the issue for you. Please let us know if the issue persist, and if you are current with your maintenance, you are welcome to log a webform with us. Gracias, Valerie!
Suggestions:
1. Open a new mxd and add the layer
2. Then walk through the same work flow
3. If the issue persist, I would run the Check and Repair Geometry on the layer
4. Then walk through the same work flow again.
Check Geometry (Data Management)
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001700000034000000
Then run the next tool
Repair Geometry (Data Management)
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Repair_Geometry/00170000003v000000/
Support Service
1-888-377-4575
http://support.esri.com/en/webform/s...275/chat/false
valerieadair
Gracias Juan,
Currently traveling. Will try this upon my return.
Tengo que irme!
Val
