Cannot add fields or assign domains in Geodtabase
570
01-14-2013 09:00 AM
MikeBly
Hi All,
I have been setting up feature classes with domains in order to maintain consistency and accuracy in our tables for attribute population, simple right? Right.
Within a file geodatabase I have been editing the feature class properties through the ArcCatalog. I have been adding fields, setting up domains and coded values within.
All of a sudden i cannot add any new field, no place to do so, there is no empty rows. I have setup four domains, just for testing, only one works, and for the other testing fields I cannot select a domain for them under the field properties, cannot type or select.
Does this make sense to anyone? I have not been able to find a solution for this seemingly simple issue.
Any thoughts would be much appreciated,
mike
