Can you help me identify what window this is in ArcMap
1786
07-27-2017 01:08 PM
JohnSkero
I am attempting to write requirements for a new ArcMap/ArcPro add-in. I came across this window at some point, but now can't remember how to find it. I believe I was viewing a Geotiff in the frame. ArcMap‌ window identification
Thanks
Window in QuestionThe small tool thumbnail. Looks like an inspection/search logo.
JohnPlunkett
Open the attribute table for your mosaic dataset
Click the <Raster>
Then you will get this image
I belive this is what you are after
JohnPlunkett
It looks like it could be the Overview/Magnifer
In ArcMap
Click Windows> Select Magnifer/Overview
Cheers
JohnSkero
Hi John,
I checked both of those. They seem similar but do not offer item description, properties, or function tabs. Thanks for the reply.
JohnPlunkett
Click the <Raster>
JohnPlunkett
If it is what you are after to close the thread if you can mark the response as correct that will be helpful jrskero1982
JohnSkero
Thanks all. John P's answer was correct!
