Can't Load Data "Field not nullable"
1374
04-13-2010 11:01 PM
tongkimongki
Dear experts,
I cant load data into my Oracle SDE because there is error "field not nullable". I've checked all fields, they have property "allow null : Yes" except the geometry field. I have tried to load data which have values for all fields but the error is still the same.
Why ?
Environment: SDE 9.3 sp 1, Oracle 10g R2, Desktop 9.3, Windows 2000 Server
Thanks before
VinceAngelo
Esri Esteemed Contributor
ArcSDE requires that the geometry column permit NULL values.  Registered
rowid columns are required to be NOT NULL.
- V
tongkimongki
Morning Vince,
I just realized that the geometry colums permit NULL values by default. As I said, i have tried to load data with non-empty values but it just wont get loaded... I dont have any null values, why do i get rejected as if i am trying to insert null values into non-null field ?
Thanks again
VinceAngelo
ArcSDE isn't generating this message, so I have no idea what is going on.
I'm assuming you're using Desktop to load.  Have you tried a command-line
loading tool with the same data?  Have you tried enabling tracing, and looking
at the sequence of functions?  Have you tried using 'sdetable -o describe' on
the table to see if the attributes agree (the rowid column cannot allow NULLs,
and must be SDE-set for ArcGIS to load it)?
- V
JoseSanchez
When I have this problem I just open the database with Oracle SQL DEveloper and change the specific field to accept null values. Do not use ArcCatalog for that.
