Can't identify coordinate system
7172
11
05-16-2019 11:23 AM
BrendanDwyer
I have some geospatial data in a text file but I can't identify the coordinate system it is using.  Coordinates were in a format like this: xyzxNx, xyzxyEx, where the x's are integers.  I think it might be a naval or military format, but I'm not sure.
It would look something like this: "3506N8 13922E5"*
Any help would be appreciated.
*not a real example, may not be plottable.
BrendanDwyer
Figured it out. It's a format used by OTH-Gold, as described in Appendix C here:
https://apps.dtic.mil/dtic/tr/fulltext/u2/a405953.pdf
Enter the position of the report in its original format and precision if possible. Use one of the alternate field contents provided below. Enter the designated field descriptor followed by the data. Data can be expressed in:
Coordinate  System    Field Descriptor
LL:                               Latitude/Longitude
UT:                               UTM (Universal Transverse Mercator)
GR:                              GEOREF (World Geographic Reference System)
The precision reported in this field should reflect the original known precision. The only boundary or restriction placed on the reported precision of data in this field is the field length range. An optional floating decimal is allowed as  appropriate, e.g., LL:304055.55N7-1304055.55E8, UT:45FDK0474, GR:DIQA
MelitaKennedy
Esri Notable Contributor
Thank you for posting that information!
