Can't edit in a different coordinate system
1030
07-02-2012 10:18 AM
ShawnDevereaux
I'm trying to edit an SDE feature class that is stored in WGS84.  I'm reprojecting to a state plane zone for editing on a local area.
I get the following message: Could not edit any of the map's layers. No data sources in the map are registered as versioned or you lack privileges to modify data sources which are registered as versioned.
I can edit it with no problems if the data frame is in WGS84 so it's not a registered or versioned problem.
Another person in the office doesn't get this error but the layer doesn't appear in the editor target list even when it is the only feature class in the TOC so there's no way a different workspace is being edited.
Any ideas?
