Can not figure out Maplex
3014
12
09-17-2012 08:39 AM
BradBlanco
Hey guys, I'm probably going to start posting here more often.  Anyways, I need to create some labels for a land map.
Our client would like the information for each section of land labeled like this, in the lower left hand corner of the square (section)
Open: 480
HBP: 160
Operators: CHK
                C&J Operating
                Kirkpatrick
Competition: N/A
# of Lease: N/A
I've gone through hours of trial and error with expressions trying to get this right.
Any help would be greatly appreciated.
B
AnthonyGiles
Honored Contributor
snowcobra,
To seperate your CHK field you will need to use a split function to create an array of values then use a for loop on these values to build up the label, have a look at this post for the usage of the split function:
http://forums.esri.com/Thread.asp?c=93&f=993&t=258334
Regarding your labels not showing at certain scales have a look at this post, it may solve your problem:
http://forums.esri.com/Thread.asp?c=93&f=1730&t=239430
Regards
Anthony
BradBlanco
I applied the repair geometry feature to each shape file to no avail.
Any other ideas?
B
AnthonyGiles
Honored Contributor
Brad,
It looks like other Maplex users are having similar problems, see:
http://forums.arcgis.com/threads/64550-Maplex-not-labeling-polygons-at-small-scale
Maybe its a bug in Maplex,
Regards
Anthony
