CAD Surfaces in ArcView
5533
10
12-20-2010 02:34 PM
ChristianRomeyn
What is the best way to take a surface from Civil 3D 2011 and bring it into Arcview? I have tried saving the TIN triangles as 3D polyines and adding them to Arcview as a CAD group layer but I can't use them to make a surface. I also tried exporting the 3D tin lines from Civil3D into a shape file but the lines do not appear to be 3d...any help would be appreciated.
MichaelMorgan
...I also tried exporting the 3D tin lines from Civil3D into a shape file but the lines do not appear to be 3d...any help would be appreciated.
One thing you might check in Civil 3D: if you're using mapexport at the commandline to create a shape file, select the options tab and click the Driver Options button, select 3D shape file and click OK.
mike
JoettaCanaan
Did you ever find a solution? I am having the same problem.
AudreyGarcia
I have been able to successfully create the TIN in ArcGIS from a CAD drawing.  I did need 3D Analyst ext to create the Terrain and then the TIN.  I have step by step instructions and would be happy to share if you would like.
marieducharme
Hello Audrey!
I am having some problems converting a 3d Cad file into a proper TIN. I would be very very interested in getting your step by step instructions!!!
Marishka
MatthewBoyle
Does anyone know how to do the reverse...?  Take a TIN from ArcGIS and drop it into AutoCAD Civil 3D?
TimGrud
I am having the same issue.  Can you share your instruction list with me.
thanks,
Tim
SaraGilbert
thanks,
Tim
Tim,
Did you figure out how to do this (CAD to TIN)?
Sara
EmilyParson
TimGrud
Tim,
Sara
Sara,  No luck yet.
I am trying work arounds.  I have 3d analyst, computed volumes in Carlson Civil using a surface from ACAD 3D.
Go figure.
Any help is much appreciated.  I ultimately want to check the Carlson Volume generated in 3D in 3D Analyst.
Nothing is easy,
tim
