CAD Segment value not showing in ArcMap
984
01-18-2011 05:02 AM
DaveCouture
We recently got ArcGIS 10 at work and we are having a hard time converting our CAD Breaklines data, into Arc Data.  We've tried everything that's listed in the Help documents, but they all produce the same result.
The CAD Breaklines have segments, which form a (continuous) line.  When converting into Arc, those segments have no values - we just get the continuous lines and their value.  This makes the TIN look wrong, since Arc is assigning one elevation per line, instead of one elevation per segment.
How can I converter the data in Arc, so it keeps all the segments with their value?
DaveCouture
We found the issue.  We had to drop the Line Element, in MicroStation, then save the file again.
