AutoCAD DWG Georeference Transformations
1310
06-25-2018 09:16 AM
deleted-user-vxpLRuAuLkA4
Applying a scale factor to a dwg file in ArcGIS Pro. Is there a setting in ArcGIS Pro to apply a scale factor to a dwg file. I see the manual tools - Move, Scale, and Rotate on the Georeference tab, but I do not see ability to apply a scale factor to the dwg features - Annotation, Point, Polyline, or Polygon that is available in ArcMap. This is a task we regularly perform on dwg files we receive from developers, or engineering firms.  #ArcGIS Pro#AutoCAD#DWG
JayantaPoddar
Did you check Move, rotate, or scale a feature—ArcGIS Pro | ArcGIS Desktop ?
Keyboard shortcutFunctionDescription
F
Scale Factor
Opens the dialog box to specify a scale factor.
Think Location
