Attribute Assistant Message
1225
11-20-2012 06:51 AM
LoriBeidler
I've converted our data into the LGIM and am using the Address Data Management 10.1 tools.  Everytime I try to place a site address point that uses the tool that's supposed to figure the address number based on the road centerline, I get an Attribute Assistant error processing the rules message: Value does not fall within the expected range.  I had it working right after installing 10.1 and I hadn't changed anything but for some reason it quit working and now I get the error.  Any ideas?
MikeMillerGIS
Esri Frequent Contributor
Lori,
   Log a tech support call, they will be able to help you.  Are all you address ranges numeric?  Did you change the config file or your centerlines schema?
