ArcSDE 32 or 64bit?
1194
07-08-2011 02:47 AM
NelsonRibeiro
I'm installing ArcSDE 10 on a Win2008 R2 64bit Server. ArcGIS Server is 32bit only. Is there any problem installing 64bit ArcSDE version. What is the best configuration?
VinceAngelo
Esri Esteemed Contributor
While it's theoretically possible to store both 32-bit and 64-bit database clients and run both
32-bit AGS and 64-bit ArcSDE on a single server, it's much easier to install *only* 32-bit Esri
apps on a single host ("easier" as in several hours less hair-pulling before giving up and just
using 32-bit ArcSDE). I once set out to prove that 64-bit ArcSDE 9.3.1 ran faster than 32-bit,
and it did (a little bit) on a 64-bit Linux VM, but it didn't on a 2008 Server VM (in fact, 32-bit
may have been a bit faster). When ArcGIS 10.1 is released, AGS will be 64-bit, and it will be
easier to run 64-bit ArcSDE.
- V
NelsonRibeiro
Thanks Vince, I'll keep it simple, 32bit, cheers.
