ArcSDE 10.1 Service sont start
1160
01-23-2013 10:35 AM
CraigMark
Server 2003
ArcSDE 10.1 (10.0 previously uninstalled) SP1
ArcGIS 10.1 SP1
Oracle 11g r2
multiple geodatabase user schema
With a fresh install of Oracle and SDE the esri service wont start...
Output of sde_esri_sde.log
ArcSDE 10.1 for Oracle11g Build 768
ST_GEOMETRY Schema Owner: (SDE) Type Release: 1007
Instance initialized for ((sde)) . . .
Connected to instance . . .
WARNING: SDETMP: Setting temp path to c:\temp
ERROR in checking system st_geometry type (1)
Error in checking the existence of system tables.
Run the upgrade Geodatabase tool to install /upgrade system tables (-450).
Refer to the ArcGIS help topics for instructions.
________________________________
Using direct connect connections (Servername:oracleport/netservice)
I try to "upgrade" each of my schemas... And I get the toolbox message "The  geodatabase is already at the current release and cannot be upgraded."
giomgr log shows... Startup, validated system paths,read server_config.... nothing unusual.
I have proper entries in drivers\etc folder...
I have proper entry in services.sde...
Any ideas??????
- Craig
ST
ForrestJones
Hi Craig,
Is your Oracle database 32-bit by chance?
CraigMark
Oracle is 64bit...
ForrestJones
Ok. I thought maybe you had a 32-bit db and the wrong error message was coming back. I think it would be best to contact support at this point if you haven't already.
