ArcHydro
4400
16
04-08-2010 10:45 AM
scottvalentine
Is there a link to the ArcHydro downloads that is operational at this tiime?  The link in the old forums just brings me back to the support login page.:)
JasonTaylor
Yes, I am having trouble with the link as well. It seems to be unavailable. Does anyone know of a mirror?
JasonTaylor
I just tried it again and it seems to be fine. I logged in to place my first post, and it worked after that. You may need to be logged in to download the zip file.
I am getting the same error as you Garth. It appears that after clicking ok through the invalid argument errors, there are several ArcHyrdo features missing from each menu. I image the toolbar will work, just not those sub tools. Too bad the install didn't come with an install readme file....
JasonTaylor
Ok, it works fine now. I closed all programs, and ran all three installers that came withthe zip file. That seems to have done the trick. Good Luck.
NilsBabel
Does anyone know if Arc Hydro for ArcGIS 10 is available?  Or if they have plans to port it to ArcGIS 10?
Thanks very much.
AbolfazlAbesht
I have installed ArcHydro and like some other friends I keep getting this message saying "5, Invalid procedure call or argument" basically when I run "catchment Polygon Processing". All other commands prior to Catchment Polygon Processing are working properly but not the mentioned one.
Could anyone-one help me on this?
jaredcunningham
I received the same error when loading the tools. I installed the other two components, XML and ApFramework, which fixed the error.
RíonaSutherland
I'm having some trouble with ArcHydro freezing up my ArcMap window. Some of the tools work but a few of them cause the program to completely freeze up. Has anyone had trouble with this? I'm running a 64-bit machine, ArcGIS 9.3.1 and just updated to the latest ArcHydro tools available on the ftp.
Is there any additional support for ArcHydro? My search continues...
