ArcGIS10 - "Ghost" Attachment table leading in mapservice launch issue
1046
08-17-2011 10:01 AM
PierreLarondelle
[Newbie inside]
Hi all,
I added several feature datasets including respectively several polygon feature classes to a map.
In order to improve the information delivered, one asks me to create an attachment to one of the feature class for testing attachments capabilities.
The map was published trough a webservice (map + feature enabled) without any issue. After testing, one asked me to delete the attachement which were not sufficiently relevant.
I delete the attachment + relation in ArcEditor still without issue. I verified in the Postgres database (driven by ArcSDE) if everything was dropped and all about it was clear.
I started to re-publish the service and then get an error message (see attached Errorpublication.jpg) telling that the service can't be published due to a table not found. The table name was the one I just deleted.
When I take a look into the Set Data Sources panel it seems that my table or at least its relationship is still present somewhere (see attached Listetables.jpg). Maybe in the SDE Table registry ?
Question is : Can you tell me what to do to break gently this sort of "ghost" relation and also pointing what I'm maybe doing wrong ?
I'm in a hurry cause the big boys are, as usual, running around me to get their toys back ... 😄
Config : ArcEditor > ArcSDE/PostgreSQL 8.3 > ArcGIS Server Entreprise, version 10sp2
Thanks a lot for any help !
Have a nice day all,
Pierre.
[/Newbie inside]
