ArcCatalog 10, Address Locator Privileges Error with ArcSDE 9.3.1SP2 Locators
2768
09-27-2010 08:13 AM
JonHall
I have been unable to use ArcCatalog 10 to assign Privileges to ArcSDE 9.3.1 SP2 Locators.
The new ArcToolbox "Change Privileges" tool does not support Locators.
The ArcCatalog right-click context menu "Privileges" opens, but returns "Address Locator Privileges Error", "Cannot grant access to the address locator <owner.locator_name>"
I am, of course, using an ArcCat 10.0 database connection as the owner of the Locator to the ArcSDE 9.3.1 SP2 database, which is running on SQL Server 2005 SP30.
Is this a known issue? Thanks!
JonHall
In ArcCatalog 9.3.1SP2, it looks the user already has privileges to the Locators in the ArcSDE 9.3.1SP2 database.  They simply do not appear in ArcCatalog 10.0
Why, ESRI, why, why why these backward incompatibility issues?!?
JonHall
Answered my own question. This falls under one of the 'Known Issues" listed on this page:
http://resources.arcgis.com/content/known-issues/10.0
07/23/10 - Issues using Locators stored in an ArcGIS 9.3.1 Enterprise (ArcSDE) Geodatabase with ArcGIS 10 clients
NIM058905 - ArcGIS Desktop 10.0 cannot see address locators stored in an ArcSDE 9.3.1 SP1 (or earlier) geodatabase.
NIM059609 - Can�??t rebuild address locator stored in ArcSDE 9.3.1 from an ArcGIS 10 client.
NIM058905 - An address locator cannot be created in an ArcSDE 9.3.1 database.
NIM059293 - Unable to save changes in the Address Locator properties window.
Patch: Planned to be included in 10.0 SP1
DanMcCoy
DanMcCoy
Looks like NIM059609 still won't be addressed in the next service pack...
http://downloads2.esri.com/support/downloads/other_/10.0_SP5_Announcement.pdf
If you are having this issue, I'd sugest contacting Tech Support and referencing the bug#.  Otherwise, it may not get addressed...
