ArcCatalog 10.1 SP1 crashes when publishing a composite locator service
4783
02-26-2013 07:57 PM
CindyWilliams
I have two locator packages shared as geocode services. I created a composite locator pointing to the two services and it works correctly in ArcMap. When I try to create a service from the composite locator in ArcCatalog, it goes through to the service editor. When I click publish, it hangs for a few seconds and then crashes. I have retried this multiple times, rebooted the machine, tried from a different admin account etc.
MichaelVolz
Esteemed Contributor
What version of ArcGIS are you using?
Can you check to see if the original locators have become corrupted?  This is an issue I am having when rebuilding locators in ArcGIS v10.1.
CindyWilliams
I updated my answer a while ago on GIS StackExchange.
