Any good SDE Geodatabase ETL Tools
2194
09-19-2011 12:52 PM
JamesFox1
Are there any good enterprise ETL tools that would be recommended for moving data between data warehouse sized geodatabases? Specifically the types of products similar to IBM Data Stage and such where you would connect to multiple data sources, grpahically and tabularly specify and script out transformation rules,..etc.
I know I could probably research this but would have to sift through and prototype tons of marketing literature, sales brochures and the like and figured this forum would be a good place to get the rundown on best products out there that have been used succesfully on large database projects.
-Jim
BruceHarold
Esri Frequent Contributor
James
The Data Interoperability extension is for this workflow, especially when dealing with SDE geodatabases.  It is likely you'll need assistance with your workbench authoring, work with your Esri account manager in this regard.  If you have many tens of millions of features to process simultaneously then memory may be an issue - bring this up in discussions if necessary.
Regards
