Any automatching function??
1290
08-03-2012 06:13 AM
GaniNessipbekov
Hi guys!
Does anyone know some sort of magic function/tool that can help me to identify and match upstream and downstream nodes for pipe network? I have nodes and pipes in two separate shapefiles. Is there any way to identify which node is US and DS and add relevant columns into pipe network shp?
Thanks!
AlexeyTereshenkov
Hi Gani,
Have you looked at the Utility Network Analyst toolbar in ArcGIS? Geometric network is a powerful way to model the type of reality you've explained.
What are geometric networks: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/What_are_geometric_networks/002r000000...
Using the Utility Network Analyst toolbar: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Using_the_Utility_Network_Analyst_tool...
AlexeyTereshenkov
Hi Gani,
GaniNessipbekov
Dear Alexey,
Thanks a lot!
Geometric network was the one I was looking for.
Now, I don't have to switch between Excel and AcrGIS.
