Another Transformation Question NAD83 to WGS84 (Melita K:HELP!)
5498
8
08-05-2015 09:11 AM
JoeBorgione
A few days ago I posted Transformation from StatePlane NAD83 to WGS84 ;  I ended up contacting tech support and they pointed me an on line doc that specifies which transformation option to use here in the lower 48.
My original confusion stemmed from a couple conversations with colleagues who just said:  "I use the default when I project"
When you use the project tool, it does indeed provide a default transformation:
I read the default as wgs84 to nad83, not nad83 to wgs84.....
However, when you use a geoprocessing tool you can set your Output Coordinates Environment Setting.  There is no default provided.  I don't see the the one highlighted above in the pick list, only the ones mentioned in the tech paper sited in my earlier post:
So at this point I'm right back to my earlier confused state....
That should just about do it....
MelitaKennedy
Esri Notable Contributor
The Project Tool is giving a 'best' choice or a sorted list based on the data's extents and the transformation extents and accuracies. The geoprocessing environment list doesn't have access to your area of interest so just gives a list sorted by names.
I usually try to define transformation in the same "order" that the source document uses. In this case, the WGS_1984_(ITRF00) one came from National Geodetic Survey CORS website. It's technically ITRF00 to NAD83 (CORS96 or HARN, more or less) and time-based, but we drop the time-based portion of the transformation.
Depending on your version, you may have more recent ones like an ITRF2008 to NAD83 (2011).
Melita
IanMurray
Honored Contributor
If you tag people in a post, then they should get an alert they have been tagged in content, since you are looking for Melita Kennedy​ on this particular question.
RebeccaStrauch__GISP
Although Melita will be able to answer any specifics better than I would even dream,
regarding this statement....the "to"   actually goes both ways.  that is it means both "wgs84 to nad83"  AND "nad83 to wgs84".
You are not the only one that was confused by that the first time they saw it.
DanPatterson_Retired
ChrisDonohue__GISP
Rebecca makes a good point on the reverse-ability of transformations. Here's what the ESRI help states:
Datum transformations work in either direction. For example, the transformation listed as NAD_1927_to_NAD_1983_NADCON transforms from NAD 1983 to NAD 1927, as well as from NAD 1927 to NAD 1983.
21327 - Select the correct geographic (datum) transformation when projecting between datums
Chris Donohue, GISP
JoeBorgione
I appreciate all the feed back- the confusion for me is in the lack of consistency between the projection tool and any other geoprocessing tool and what transformation method(s) is/are available.
For the last 25+ years, I've been using projected data for all my analyses.  The trend now at least in the 9-1-1 industry where I work is migrating to GCS...
MelitaKennedy
Melita
JoeBorgione
Thanks Melita! That pretty much clears it up for me!
MelitaKennedy
I'm glad to hear that, Joe! This stuff isn't getting simpler, it's getting more complicated now that we have better solutions and datum re-adjustments.
