Alternative to Disperse Markers tool?
5627
02-16-2012 09:07 AM
RyanUtter
I do not have the licence to use the disperse markers tool, but it is exactly what I need. Is there an alternative way to do it aside from manually assigning locations?
KirstenPinkston
Esri Alum
If you have the Maplex extension, there is an alternative workaround provided at the link below:
How to display coincident points with Maplex
http://blogs.esri.com/Support/blogs/mappingcenter/archive/2007/08/27/displaying-coincident-points.as...
If you do not have the Maplex extension, the following ArcScript may provide the desired results:
Duplicate_Mover Custom Script
http://arcscripts.esri.com/details.asp?dbid=15365
